I'm currently in the process of identifying the thickness of insulation for a pipeline. I wanted to know in what circumstances can hi be greater than ho? I've tried to look this up however I can't find anything.
Thank you very much
Posted 28 March 2015 - 05:21 PM
Thank you very much
Posted 04 April 2015 - 07:49 AM
if you mean the internal and external surface heat transfer coefficients
the value depends from the characteristics of the two fluids (internal / external) and conditions.
Time Required To Heat Up A Fluid In A VesselStarted by Guest_panagiotis_* , 24 Jan 2023 |
Plate Fin Heat ExchangerStarted by Guest_shazzad1613_* , 23 Mar 2024 |
Heat Exchanger Temperature CrossStarted by Guest_kaidlut_* , 20 Dec 2022 |
