Hi guys,
I have a question regarding the spraying pressure of a water tank.
Suppose I have a storage tank for water with the following parameters:
Height: 10 m
Capacity: 651900 liters
There is a hole on the tank shell, almost at the bottom of the tank (assume that it is at the bottom) and the hole has a diameter of approximately 11 mm.
What would be the pressure of the water spraying out at that depth?
What I know so far, is the hydrostatic pressure at that depth in the tank, which is 14.2 psi.
But the pressure increases when it is sent through the small hole right?
Can I apply Bernoulli's formula to calculate the pressure of the water spraying out?
I'm not sure. And even if I could use that, I don't have any speeds of fluid.
Any ideas?
