I am currently calculating the pressure losses and the NPSH for a new pump that will be installed downstream an existing tank.
How should I account for the pressure drop in the nozzle?
Thanks,
Sherif
Posted 12 May 2015 - 11:27 AM
Thanks,
Sherif
Posted 12 May 2015 - 11:39 AM
Sherif,
For a sharp edge nozzle entrance getting 0.5 V2/2g is a good estimation for head loss in the tank outlet nozzle...
Posted 12 May 2015 - 12:43 PM
Thanks for the reply.
Regarding the calculation of NPSH using API 14E (Page 20), if the tank is atmospheric, how would you account for the absolute pressure head in feet? Is it Rho x g x h?
Posted 12 May 2015 - 01:01 PM
Sherif,
It is as follows:
NPSHA= Available Static Head (Tank Low Low Level-Center Line Level of pump Suction Line)+ Corresponding Head of local Absolute Atmospheric pressure-Head Loss due to entrance and friction-Vapor Pressure of the Fluid at Operating Temperature
Absolute pressure Head in Feet=Absolute pressure (psi)*2.31/SG (Specific Gravity)
Posted 12 May 2015 - 01:42 PM
Sherif,
I would add that you should consider purchasing Crane Technical Paper 410, Flow of Fluids.
It is an excellent reference for calculating fluid flows, losses etc. I believe that most of the engineers on this forum use this reference.
Posted 12 May 2015 - 01:59 PM
Thanks alot for your feedback....
Posted 15 May 2015 - 12:05 PM
proinwv,
A copy has been ordered already Appreciate your advice
Posted 15 May 2015 - 01:27 PM
I believe that you will get many years use of this. Enjoy!
Posted 30 July 2015 - 08:52 AM
I got Crane 410. I am currently working some numbers and things are critical given the low NPSHA due to space limitations.
For the pressure drop across the 8" nozzle located at the bottom of the tank (2.7 x 2.7 x 1.4), I am calculating the pressure drop across it using Eq 2-23 page 2-14.
For the factor C, I am referring to the graph on page A-20 (appendix A).
Is that a correct approach? If so, in estimating the ration B=d1/d2, I considered it the ratio between the nozzle size and the tank width, i.e. 0.2032m (8") divided by 2.7m. If not, please advise.
Fallah, just confirming your equation. Is it 0.5 v^2/2g or v^2/2g?
Thanks,
Sherif
Posted 30 July 2015 - 10:00 AM
For the tank nozzle, use Crane page A-29 PIPE ENTRANCE
For a sharp-edged entrance (r/d = 0.00) you see that K = 0.5
In other words: the head loss of a sharp-edged pipe entrance (tank exit) nozzle is 0.5 velocity heads,
or as fallah put it: 0.5 * (v2/2g)
Edited by PingPong, 30 July 2015 - 10:02 AM.
Posted 31 July 2015 - 11:40 AM
Thanks for the feedback.
But why can't I use Euqation 2-23 (Page 2-14)? It's under the title "Flow through Nozzles and Orifices".
Posted 31 July 2015 - 01:24 PM
Because that is not about tank nozzles.
The definition of nozzle there is that of a restriction in a line, for example to measure (meter) flow. It is then a low pressure alternative to an orifice plate. See first figure on page A-20.
And read first line on page 2-14: Orifices and nozzles are used principally to meter rate of flow.
Posted 01 August 2015 - 06:10 AM
Thanks,
Sherif
You can also refer coulson & Rechardson Volume 6
Edited by Kiran T, 01 August 2015 - 06:11 AM.
Posted 19 August 2015 - 12:47 PM
Hi Kiran,
What's the source of that table?
Sherif
Posted 21 August 2015 - 03:37 AM
As Kiran indicated, it is from:
Coulson & Richardson's Chemical Engineering Series, Volume 6 (Chemical Engineering Design)
Note that, like Crane, it also indicates a pressure loss of 0.5 velocity heads for a Sharp reduction (tank outlet),
and you can find that well known fact in many other books.
Vacuum Pump Power EquationStarted by Guest_hysyshunter_* , 22 Apr 2024 |
