What Causes Pressure Drop Increase As Flowrate Decrease?
8 replies to this topic
#1 camad
camad
  • 6 posts
Posted 21 July 2015 - 02:40 AM
Let says that gas outlet pressure for my LP separator is 6 bar (fixed) and it going to gas compressor. The inlet pressure for gas compressor decrease as flowrate decrease. I show you some example :-
For inlet pressure for gas compressor 4.7 bar, the flowrate is 23mmscfd but for inlet pressure for gas compressor 3.3 bar, the flowrate is 18mmscfd.
Why this happened? Can anyone explain to me please. Thank you.
*These are further information that might be useful
-current supplied to operate the motor of gas compressor is decreased
-anti-surge control valve for gas compressor is increased
-more percentage of gas leaving from LP separator going to HP flare
#2 shan
shan
  • 692 posts
Posted 21 July 2015 - 06:29 AM
To maintain the same actual volumetric flow.
#3 camad
camad
  • 6 posts
Posted 21 July 2015 - 07:41 PM
Could you explain further please mr shan?
#4 latexman
latexman
  • 1,688 posts
Posted 22 July 2015 - 06:09 AM
A P&ID of this process would help us help you.
#5 shan
shan
  • 692 posts
Posted 22 July 2015 - 07:01 AM
You have a positive displacement compressor (I guess), which compresses the identical actual volume of gas at the suction conditions for each stroke.  The same actual volume of gas at higher pressure is larger than that at lower pressure when the gas is converted to the standard conditions.
#6 camad
camad
  • 6 posts
Posted 26 July 2015 - 11:08 PM
Data for pressure drop
from left : data at jun 2013, jun 2014, and jun 2015
V1030 Outlet Pressure (bar)
6.017
6.002
5.99
V1030 Outlet Flowrate (mmscfd)
23.358
21.521
20.894
K2430 Inlet Flowrate (mmscfd)
23.772
21.978
17.535
K2430 Inlet Pressure (bar)
4.739
4.011
3.543
K2430 Inlet Temperature (degree celcius)
62.036
61.629
61.266
K2430 Outlet Pressure (bar)
23.982
22.795
23.537
K2430 Current to Operate the Motor(A)
221.692
217.391
197.045
V1030 Outlet Flowrate (MMCF/D)
15.766
17.107
15.362
https://cdn.fbsbx.co...e=55B7A2B8&dl=1
https://cdn.fbsbx.co...e=55B7C792&dl=1
I hereby attached some link to my PFD and graph, hopefully u guys cab help me. Thank you.
#7 camad
camad
  • 6 posts
Posted 27 July 2015 - 12:53 AM
FYI, I am using dynamic compressor which is centrifugal compressor. Why does the compressor maintain the inlet volumetric flowrate? Is it to maintain the efficiency of compressor or any good reason? Thank you for your reply sir.
#8 shan
shan
  • 692 posts
Posted 27 July 2015 - 06:29 AM
6 bar is the LP Separator operating pressure (inside vessel pressure not "outlet pressure"), which is controlled by a PCV.  The pressure at downstream of PCV is controlled by the compressor.  The same actual volumetric flow rate is because of the same RPM of the compressor.  The higher differential pressure of compressor is, the lower compressor flow rate per the compressor performance curve.
#9 camad
camad
  • 6 posts
Posted 03 August 2015 - 12:12 AM
Mr shan.. May I know what is the equation that I should use to calculate the actual volume?? FYI, im using dynamic compressor with constant rpm and straight through impeller.. How does this effect the actual volumetric flowrate? If I was not mistaken, suction pressure increase as flowrate increase buat discharge pressure increase as flowrate decrease.. Am I right?? Could you elaborate it?? Thanks sir
Edited by camad, 03 August 2015 - 12:14 AM.
