Pressure Loss In Pipe Fittings At Low Reynold Number
8 replies to this topic
#1 ashishmishra1234
ashishmishra1234
  • 19 posts
Posted 27 September 2015 - 06:32 AM
Dear Freinds,
Can any body have experience in designing the piping at very low Reynold number ( 0.001 to o.1 ) for highly viscous fluid having viscosity 23750 Pa s. I tried hooper 2 K method but it results overestimated pipework .
Ashish
#2 katmar
katmar
  • 668 posts
Posted 27 September 2015 - 12:46 PM
The viscosity you are working with is well beyond the range normally encountered in fluid mechanics calculations.  It is around 50x that of molten glass and processing it would fall more in the realm of extrusions than pipe flow (as understood by chemical engineers).  I think you will have more chance of getting good information on one of the plastics forums.
#3 breizh
  • 6,347 posts
Posted 27 September 2015 - 10:47 PM
Hi Ashish,
Can you give us indication about the material and process condition ?
#4 ashishmishra1234
ashishmishra1234
  • 19 posts
Posted 28 September 2015 - 12:24 AM
Sir I am dealing with the sugar industry. The fluid is the low grade massecuites ( mixture of sugar crystals and sugar syrup. The specific gravity of this fluid is around 1450kg/m3. Regards Ashish
#5 breizh
  • 6,347 posts
Posted 28 September 2015 - 12:57 AM
http://www.sugartech...rdata/index.php
Consider this resource , you may contact them to get useful information.
Go to pipe sizing under general engineering  in the link and provide the necessary info about your material ( Brix,...)
Good luck.
Edited by breizh, 28 September 2015 - 07:18 AM.
#6 ashishmishra1234
ashishmishra1234
  • 19 posts
Posted 28 September 2015 - 09:59 AM
Sir,
The resource suggested in not giving any full proof method for calculating the pipelines at verry very low Re. Does any one have informations  for flow at low Re, Pls share .
Ashish
#7 breizh
  • 6,347 posts
Posted 29 September 2015 - 07:11 AM
In addition to my previous post , consider this document to support your work.
Good luck.
#8 katmar
katmar
  • 668 posts
Posted 27 October 2015 - 08:14 AM
I came across the paper referenced below which deals specifically with high viscosity materials in the sugar industry. The authors also comment that at those very low Reynolds Numbers the Hooper 2K method over estimates the pressure drop.
http://www.assct.com...1994_pa_m46.pdf
#9 ashishmishra1234
ashishmishra1234
  • 19 posts
Posted 17 December 2015 - 11:31 AM
Thanks Sir
