alirehman:
You are furnishing unrelated and confusing information meant to generate a recommendation. That is why Fallah is responding in the way that he has. He - like most of us - are confused by the explanation of producing Acetic Acid by oxidation of ethylene. Apparently, all you want to do is design an adequate LIQUID ethylene (at what temperature & pressure?) vaporizer to feed the resultant vapor (presumably saturated?) to some process - and that is all. So why even mention Acetic Acid?
Why don't you use common sense and give us the BASIC DATA: conditions of the liquid fluid to be vaporized, the desired conditions of the vaporized fluid, the flow quantities involved, and the heat source(s) available to carry out the vaporization and their flow rates?
Why do you give the forum un-related and unnecessary information like the "melting point" of ethylene? Are you vaporizing a SOLID? I don't think so! You state the "boiling point" is -103.7 oC - as an engineering student you should already know that this information is irrelevant if you don't also identify the PRESSURE corresponding to that boiling point! Liquids boil at different temperatures under different pressures. That is basic knowledge.
Our key and expert engineers - like Fallah - have all the knowledge and expertise to help you. But you must help them to allow them to help you. You help them by furnishing clear, concise, specific basic data and information related to your query. Otherwise this thread will quickly convert itself into a guessing contest and you will gain or profit nothing from it - only a lot of lost time and effort. Help our Forum members and you will be rewarded with their valuable advice and recommendations. Let this be a Lesson Learned.
