Heat Transfer In Water Tank
#1 MLS3006
MLS3006
Posted 27 April 2016 - 11:56 AM
I would like to determine the heat transfer rate from an insulated, uncovered, cylindrical tank. The liquid in the tank will be pre-heated and there is no continuous heating. The tank will be outdoors at varying ambient temperatures (from -20 to +30 degC). I will assume no wind. The liquid will be a 7% KCl solution. I want to calculate time for the liquid temperature to reach 40C given initial heating to each of 45, 50, 55degC. I am waiting on the tank specs (size, insulation, etc)
I have discarded my ChE heat transfer textbook and it has been 10 years since I've done this type of calculation. Can someone please advise the formulas I need to use?
Thanks.
  • 6,349 posts
Posted 27 April 2016 - 06:08 PM
Let you try the search engine in this forum , a lot of stuff are available . Key words "tank heat loss"
#3 samayaraj
samayaraj
  • 239 posts
Posted 27 April 2016 - 10:05 PM
As Mr. Breizh said above, lots of thread discussed in the same topic. To help you bit, look at the attached link.
http://www.cheresour...othari-article/
Edited by samayaraj, 27 April 2016 - 10:09 PM.
