Hi there,
I am designing -both process and mechanical designs- a kettle boiler for the purpose of cooling a styrene reactor effluent stream from 610C to 240C by the vaporization of sat water at pressure 15 bar.
1- I'm searching for a go-by to follow but haven't found any but Coulson's example and i'm wondering if it is enough or not for doing a detailed design and whether there are any avalible solved examples to follow?!
2- For the tube side heat transfer coeffiecient and pressure drop calculations should i follow the same procedure as that done in normal shell and tube exchangers or something will change?
3-What is the effect of the presence of u-tube bundle in my design instead of the normal tubes?
If there is any information that you need in order to give a more helpful answer please mention it
Thanks in advance
Kettle Boiler Design
Started by Omar U, May 02 2016 03:29 AM
No replies to this topic
Posted 02 May 2016 - 03:29 AM
Design And Fabrication Of Reflux DrumStarted by Guest_Femi_* , 22 Apr 2024 |
Jt Based Hcdp Design V/s Mechanical Refrigeration Hcdp Unit.Started by Guest_BabRafiq1_* , 19 Apr 2024 |
Rupture Disc DesignStarted by Guest_chaupradip_* , 13 Apr 2024 |
Falling Film Reactor Design CalculationStarted by Guest_Emranm02_* , 07 Apr 2024 |
Kettle Reboiler Flow FractionsStarted by Guest_Lyne_* , 31 Mar 2024 |
