Hello there;
I have been asked to design a flash tank separator for Ammonia...
i used the k from Watkin's curve and used it to find the maximum allowed vapor velocity,followed by the Diameter of the drum. Calculated the length of the drum for the typical ratio used ... L/D =3/1
now my Question is: are there parameters enough when it comes to design of a flash separator..?
I have noticed in design of throttle, that its unit is in velocity ...So i have to use that maximum throttle velocity to find the diameter of the opening or valve ,as the volumeteric flow rate of feed is known to me...or the maximum throttle velocity itself is a design parameter that i need to show.?
last question.:
i was told by an engineer from industry that the temperature is considered to be same thought the separator ?
why is that ? ist the temperature gonna drop due to joule-Thomsom effect ?
and is the pressure drop is only due to the fact that the components are being separated and the overall pressure drops due to the decrease in the partial contribution of the separated component ...?
if this is the case then where is the pressure drop that occurred at the throttle ,regained ?
