Hi All !
Could someone pl. explain what is the phenomena that causes the liquid, that flows through a valve causing the pressure drop, to partially evaporate (phase change).
Posted 30 June 2016 - 04:45 AM
Hi All !
Posted 30 June 2016 - 05:20 AM
meer,
Evaporation in liquid passed through a valve would be happened when downstream pressure is equal to or lower than the vapar pressure of the liquid at working temperature...
Answered
Steam Pressure Requirements For Limpet Batch ReactorStarted by Guest_golegolegole_* , 10 Apr 2024 |
Pressure Control Valve Issues For Gsw LinesStarted by Guest_fahadazh_* , 29 Mar 2024 |
Vapor PressureStarted by Guest_Hamza1111_* , 23 Mar 2024 |
Answered
Vacuum Ejector Pressure ControlStarted by Guest_himanshu.ch_* , 19 Mar 2024 |
