Hello All,
I'd like to know if a water-hydrocarbon separator (2 liquid phases, no gas phase) working at 2 bar and ambient Temperature with maximum operating temperature = 40 C would require any sort of pressure relief device.
My concern is in the case if hydrocarbon flashing takes place.
Thanks.
Does A Separator Need A Pressure Relief Device
Posted 28 July 2016 - 02:06 PM
Posted 28 July 2016 - 03:56 PM
Every pressure vessel should be protected against excessive overpressure. There are many codes and standards concerned with the design and application of pressure relief devices. A competent, fully trained person should be assigned to apply the rules of your governing standard.
Posted 28 July 2016 - 06:42 PM
If the vessel is ASME stamp-ed, you can check UG-140 of ASME section VIII.
Edited by christopherchoa, 29 July 2016 - 01:26 AM.
Posted 14 August 2016 - 08:07 AM
Mohamed Hussein,
If the separator is working at 2 barg its design pressure would certainly be higher. Then, if the design code is ASME Sec VIII Div.1 it needs PSV anyway other than if UG-140 conditions being provided in the separator.
Design Compressor For 35% H2S & 1.05Ksca Suction PressureStarted by Guest_GanjiS_* , 29 Apr 2024 |
Answered
Steam Pressure Requirements For Limpet Batch ReactorStarted by Guest_golegolegole_* , 10 Apr 2024 |
Pressure Control Valve Issues For Gsw LinesStarted by Guest_fahadazh_* , 29 Mar 2024 |
Vapor PressureStarted by Guest_Hamza1111_* , 23 Mar 2024 |
