Hi, forum
I'm in charge of basic design of water treatment for a refinery. Does anybody have information about steam reforming catalyst poisons? As I've found there are several poisons:
- clorine
- arsenium
- vanadium
- phosphates (only phosphates, may be all P-containing?)
What is max allowable poison rates? Any links, articles or manuals would be worth.
And else can anybody share links about reforming catalyst sintering promoters? Is it Ar and/or V or may be any other chemicals?
Ch4 Steam Reforming Poisoning
Posted 21 August 2016 - 11:25 PM
Posted 22 August 2016 - 09:06 AM
Shvet
Sulphur is also poisonous (including the substances you mentioned) for steam reforming catalyst.As far I remember,its conc was maintained less than 10 ppm for safe operation.But it varies depending upon catalyst composition.
Usually manufacturer add some additives in Ni catalyst to make it immune for poisonous substances(upto some conc.)
It will be better if you contact catalyst supply vendor.They have the poison & conc specification for the same.
Aditya
Posted 25 August 2016 - 11:13 PM
May you please relate how the water treatment relates to the poisoning of the reforming catalyst?
Are you talking about boiler feed water treatment?
Posted 27 August 2016 - 10:40 PM
Yes, I'm talking about BFW source.
H2O source in reforming reaction is BFW or demi-water, Catalyst poisons come both with feed and steam. Any catalyst poison, for example Cl-, came with BFW to steam reformer boiler will come to be in steam. So many reformer manufacturers limit some ions in demi-water.
I have an unusual source of demi-water - distillator / evaporator and I would like to know:
- which of ions manufacturers usually limit in BFW/demi-water
- what are max limits of this ions
- which type of evaporator eftertreatment stage would be worth - reverse osmosis or electrodialysis or electro deionizer or something else
Edited by shvet, 27 August 2016 - 10:59 PM.
Posted 28 August 2016 - 02:06 PM
If you use the "VGB Powertech Service GmbH, Guidelines for Feed Water, Boiler Water and Steam Quality" guidelines you should be OK.
Salts are not carried into the steam, unless the boiler have liquid carryover problem. An exception is silica that is volatile in high pressure boilers, but the VGB guidelines address this specifically.
Nickel based reformer catalysts are quite robust and usually they are changed because of mechanical deterioration (higher pressure drop) or loss of surface because of the operating temperature. Not because poisoning from steam that meets the above guidelines.
Of course, any reputable catalyst vendor you purchase the catalyst from (Topsoe, Clariant, Johnson Mattey or Unicat) can also provide a more detailed guideline.
Posted 28 August 2016 - 10:29 PM
Doubtful. Even distilled laboratory water has more ions than some vendors specified. For example usual distilled water in laboratory has:
- total dissolved solids <5 ppmw
- Cl- <20 ppbw
- conductivity <0.5 mS/sm@20°C
- pH 5.6-6.4
- SO4- <0.5 ppmw
- NH4+ <20 ppbw
So as you can see even conductivity is too high to use distilled (laboratory) water as BFW for high pressure boilers. As far as I know some vendors specifies demi-water with stricter limits of SO4, Cl and conductivity. In my case instead of laboratory distillators I have industrial distillator / evaporator which concentrates waste water. So in this distillator raw water has more contaminants than usually potable water for distillators in laboratory.
Edited by shvet, 28 August 2016 - 10:40 PM.
Posted 29 August 2016 - 09:49 AM
Doubt is a good thing. It moves you to investigate more.
Control Philosophy In Steam ReboilersStarted by Guest_halkeshhulk_* , 07 May 2024 |
Flash Steam Vessel SizingStarted by Guest_JohnFields343_* , 24 Apr 2024 |
Steam AccumulatorStarted by Guest_Valeriacortez11_* , 15 Apr 2024 |
Answered
Steam Pressure Requirements For Limpet Batch ReactorStarted by Guest_golegolegole_* , 10 Apr 2024 |
