Can we connect a non code vessel (design pressure less than 15 psig) to flare header (design pressure 700 kPag)
Non Code Vessel Connected To Flare Header
Started by bhardwaj1482, Oct 10 2016 09:20 PM
Posted 10 October 2016 - 09:20 PM
Posted 10 October 2016 - 10:54 PM
Sounds like a foolish idea.
Posted 11 October 2016 - 12:57 AM
You can connect; but aren't allowed to operate...!
Posted 11 October 2016 - 07:04 AM
bhardwaj,
Please use consistent units in a post. Why must EVERYONE do the conversion, when you could do it once. Make efficient use of the resources.
Flash Steam Vessel SizingStarted by Guest_JohnFields343_* , 24 Apr 2024 |
Handling The Limited Capacity Of Flare SystemStarted by Guest__1angelia23_* , 05 Apr 2024 |
Time Required To Heat Up A Fluid In A VesselStarted by Guest_panagiotis_* , 24 Jan 2023 |
Let Down Vessel In Methanol ProcessStarted by Guest_Manue_* , 21 Mar 2024 |
Asme Code For Fiberglass Pressure Tank FeaStarted by Guest_Pheeto_* , 13 Feb 2024 |
