Whenever steam escapes in the atmosphere it creates lot of sound but when high pressure air escapes it does not produce that high sound level . Why ?
Sound In Steam Flow
Started by ayan_dg, May 17 2008 06:54 AM
Posted 17 May 2008 - 06:54 AM
Posted 20 May 2008 - 02:53 AM
Dear,
Just find some information here,
http://cdsads.u-stra...STIN...7526281D
as well you will find some extra information here,
http://en.wikipedia...._pressure_level
Posted 22 May 2008 - 01:28 PM
QUOTE (ayan_dg @ May 17 2008, 06:54 AM) <{POST_SNAPBACK}>
The sound speed of a two-phase fluid, such as a magma-gas, water-air, or water-steam mixture, is dramatically different from the sound speed of either pure component.
The sound speeds of the pure liquid and gas are nearly independent of pressure, but the sound speed of a mixture is highly dependent on pressure and temperature (difference of pressure at the exit of a pipe). The sound speed in a single-component two-phase system, such as a water-steam mixture, depends on whether or not equilibrium between the phases on the saturation curve is maintained. Heat and mass transfer which occur when equilibrium is maintained and cause the sound speed to be much lower than under non-equilibrium conditions in which heat and mass transfer are absent.
Flash Steam Vessel SizingStarted by Guest_JohnFields343_* , 24 Apr 2024 |
Steam AccumulatorStarted by Guest_Valeriacortez11_* , 15 Apr 2024 |
Answered
Steam Pressure Requirements For Limpet Batch ReactorStarted by Guest_golegolegole_* , 10 Apr 2024 |
Flow Switch High RangeStarted by Guest_Lyne_* , 11 Apr 2024 |
