For sizing two phase line what will be recommended velocity. Whether we consider Gas flow & liquid flow separately?Please explain how to calculate the velocity.
Stu.
Velocity For Two Phase Line
Started by stu, Jul 12 2008 05:07 AM
Posted 12 July 2008 - 05:07 AM
Posted 14 July 2008 - 06:28 AM
stu,
This subject can be very completed by considering phase separation, gas and liquid flowing in different velocity, entrainment liquid into gas, liquid droplet in vapor coalescing and deposit on liquid in the pipe run, disturbance wave spreading, Secondary flow, flow pattern, etc...Just too complicated and too wide to discuss...
but you may analyze it in a simple way by considering they are homogeneous.
The properties e.g. density, viscosity, etc can be analogue homogeneous properties but this will increase the error and accuracy between calculated value and real value.
you may also consider to use empirical equation. Read more in GPSI Fluid flow chapter.
For criteria, each company may have their own criteria. Again, these criteria is subject to balance between material cost and energy cost, design life, vibration level, noise level, etc. For offshore application, one of the common published reference is API 14E using C-factor method.
Barometric Legs Line SizingStarted by Guest_panagiotis_* , 17 Mar 2023 |
Fired Heaters/ Burners/ Flue VelocityStarted by Guest_Lyne_* , 15 Mar 2024 |
Higher Pipe Line Dia Specification In UnisimStarted by Guest_Praveen Perumandla_* , 27 Feb 2024 |
Sizing Of Cooling Water Pipe LineStarted by Guest_Asif Azeez_* , 08 Jan 2021 |
Line Sizing CalculatorStarted by Guest_nhuthoahuynh13_* , 27 Nov 2023 |
