In refinery there is only two types of welding viz. socket welding for small bore (upto 1.5") & butt welding for large bore(>=2").Why fillet welding is not there ?
PME
Piping
Started by PME, Oct 01 2008 12:05 AM
Posted 01 October 2008 - 12:05 AM
Posted 01 October 2008 - 06:26 AM
PME:
What is your knowledge of welding and pipe fittings? Are you a certified welder? Have you ever welded steel?
The reason I am asking the above is that your question contradicts itself and, therefore, shows that you have an incorrect grasp of what you are asking. A fillet weld is what is applied to a socket type of fitting. A fillet is NOT A FULL PENETRATION WELD and, as such, is not very strong.
A full-penetration butt weld is inherently a full penetration weld and offers the strongest and most mechanically strong weld you can achieve on a joint. In some instances it has been shown to be STRONGER than the joint itself.
I have made butt welding mandatory on pipe joints as small as 1" in plants where I was using schedule 80 & 160. I seldom, if ever, employ socket joints or slip-ons. The fillet weld, in my opinion is restricted to low pressures and is not very strong - regardless of the pipe or joint size.
I recommend you obtain and study the various piping and welding books that are available throughout the Internet. Every engineer should have a reasonable knowledge of welding types and techniques.
Posted 20 October 2008 - 02:01 AM
Thanks for your valuable comments.
PME
PME
Piping Design_ Pump PipelineStarted by Guest_anh.phungthai@boydensvn_* , 29 Feb 2024 |
Pressure Drop In PipingStarted by Guest_Jaldhipatel_* , 05 Jun 2022 |
Two-Phase Flow Piping DesignStarted by Guest_Vegeta_* , 09 Dec 2022 |
Piping Systems For VacuumStarted by Guest_alphite_* , 20 May 2022 |
Pumping - Elevated PipingStarted by Guest_Bill B7_* , 02 Feb 2022 |
