Hi:
What is the difference between flushing time and residence time?
if there is no difference can we use residence to calculate the time, water will take to circulate through 150 gpm amine plant. The vessels, the water will circulate through are Amine still,Flash tank, sock filter, re boiler and lean/rich exchanger.
please reply me.
Thank you very much in advance.
Flushing Time
Started by process705, Apr 06 2009 01:14 PM
Posted 06 April 2009 - 01:14 PM
Posted 07 April 2009 - 09:23 AM
Hi Process705
About your question, for clarify your knowledge, please look at this contact:
http://www.machinery...p?articleid=207
Good luck.
Good luck.
Time Required To Heat Up A Fluid In A VesselStarted by Guest_panagiotis_* , 24 Jan 2023 |
Instrument Air Calculation Based On Strokes Time And Freguency In GasStarted by Guest_keren_* , 04 Oct 2023 |
Inquiry On Calculating Residence Time Of Fluids In SeperatorStarted by Guest_MJA99_* , 07 Oct 2023 |
Bulk Residence Time In Naphtha CrackingStarted by Guest_mehul_* , 19 Oct 2018 |
Answered
How To Calculate Half-Time Of ReactionStarted by Guest_chemtoli_* , 22 Aug 2023 |
