Hi All
I am a student and I am new at this topic.
For my thesis I need to develop an algorithm for the design and off-design condition of a condenser in a steam plant.
I am getting confused with a very basic issue. Could somebody say me what happens at the pinch point temperature difference in off-design? At design point we choose it (considering several issues), but for the off design? Can this difference decrease?
Many many many thanks
Maddy
Pinch Point Temperature Difference
Started by Maddy, May 30 2009 11:29 AM
Posted 30 May 2009 - 11:29 AM
Posted 03 June 2009 - 08:35 AM
If you choice delta T_min, the pinch point is fixed.
You can calculate heat duty as avaliable, required, net, accumulated.
If you finish your calc, find least accumulated. That is the pinch point.
Another method, you can make composite curves.
then you can choice the pinch point.
the hot stream cruve is fixed. then you can shift the cold stream curve.(left or right)
from the composite curves, you can decide amounts of heating and cooling utilities.
if you choice biggest temp diff, you can get small heat-exchanger but you have to pay more money to use heating and cooling utilities.
otherwise, if you choice least temp diff, you get big heat-exchanger but you can save utiilies's cost.
it depends on you.
p.s I'm not a american. I'm a korean. so my english is so terrible. Plz, understand.
it depends on you.
Posted 13 June 2009 - 01:30 AM
Caloric Temperature CalculationStarted by Guest_bckesim_* , 10 Apr 2024 |
Hydrocarbon Dew Point Control UnitStarted by Guest_BabRafiq1_* , 05 Apr 2024 |
Heat Exchanger Temperature CrossStarted by Guest_kaidlut_* , 20 Dec 2022 |
Temperature Cross Heat ExchangerStarted by Guest_Priolo_* , 12 Aug 2019 |
Cross Temperature In Heater Exchanger (Lng)Started by Guest_Yogan_* , 21 Feb 2024 |
