Carbon Dioxide Recovery
#1 skiddo
skiddo
Posted 26 August 2004 - 05:24 AM
Hi all
Can any one recommend to me a method that may be used on maximising carbon dioxide recovery from a fermentation process?? Your help will be highly appreciated.
Skiddo.
Posted 26 August 2004 - 11:47 AM
Skiddo:
On March 25th of this year I responded to Lea on the same subject in this forum - sort of, since the process was not defined. Fermentation is one of the processes I've extracted CO2 from.
Read the prior post and follow the same directions I've given there. Lea never responded, so I never followed up. Don't fail to be specific and clear in your basic data and scope of work. The quality and quantity of my response will be directly proportional to the amount of basic information received. The less you force me to guess and assume certain basic data, the more specific and accurate will be the response. Do not fail to give me a scope of work - no matter how little effort you've put into it. Since this is an industrial forum, my response will be exactly as it would be done in a conventional, operating plant - specific, direct, and detailed to the extent of the basic data supplied. In other words, tell me exactly what you need and how you propose to implement it or under what restraints. I'll respond to the best of my ability and resources.
You can reach me directly by email through the forum, in order to avoid giving your email in the forum. I'll await your response and in its absence, will assume no further interest on your part.
Spring, TX
