I need information regarding fires caused by insulation in piping system.
Insulation Fires
Started by Purav Desai, Jul 28 2009 11:15 PM
Posted 28 July 2009 - 11:15 PM
Posted 01 August 2009 - 10:10 PM
QUOTE (Purav Desai @ Jul 29 2009, 12:15 PM) <{POST_SNAPBACK}>
Good day ,
Self ignition temperature can drop very much when Organic materials are leaking inside divided material like rock whool . Consider other insulation material like PU foam or silica based material
regards
Posted 06 August 2009 - 05:43 AM
QUOTE (Purav Desai @ Jul 29 2009, 12:15 AM) <{POST_SNAPBACK}>
Purav,
Fires are generally caused not by the insulation as such, but due to an ignition source causing the insulation which is soaked with hydrocarbons (generally heavy hydrocarbons) to ignite it. The soaked insulation can also get ignited on its own, if the pipe surface temperature is above the auto ignition temperature of the hydrocarbon.
regards,
Benoy
Hot InsulationStarted by Guest_Lyne_* , 14 Apr 2024 |
Insulation Of Fired Heater StacksStarted by Guest_Sherif Morsi_* , 05 May 2020 |
Insulation Of Fired Heater StacksStarted by Guest_Sherif Morsi_* , 26 Apr 2019 |
Personnel Protection Insulation For Cryo ServiceStarted by Guest_Sara Owens_* , 06 Dec 2018 |
Heat Losses Through Cold InsulationStarted by Guest_Movers_* , 02 Oct 2018 |
