Most of us nowadays depend on simulators (HYSYS, Pro II, Chemcad & others) for obtaining flash vapor & liquid compositions by modelling a separator with an inlet stream of a given composition and pressure and temperature. A vapor stream & liquid stream from the separator will give the vapor and liquid compositions respectively. However, the actual mechanism & equations for isothermal flash in simulators is not known to many. The attached spreadsheet is a humble attempt to provide flash calculations using a set of algebraic equations. The spreadsheet is basically provides the solved example given in the reference book from which the spreadsheet is developed.
Comments are most welcome.
