 PIPESIZE PIPESIZE
| Category: | Bulk Solids |
| Question: | What can cause bulk solids to stop flowing from a bin? |
| Keywords: | v1i2,bulk,solids,rathole,stop,cease,flowing |
| Answer: | Causes of such problems can fall into one of two categories:Material strength or Bin Geometry:Factors that can affect material strength include:1. Moisture-especially with particles which fuse together with moisture. (i.e. cement, salt, sugar)2. Particle shape3. Cohesiveness4. Static Charge5. Elastic Springback6. Cycling of Temperature from hot to cold (see item 1)The bin geometry can also have adverse affects on the ability of bulk solids to flow. Characteristics that are undesirable include:1. Square corners2. Shallow hopper slopes3. Non-movement of material along walls Source: bulkprocessingequipment.com |
| Links: | Bulk Processing Equipment |
					 Bulk Solids Bulk Solids
					 Corrosion Corrosion
					 Fluid Dynamics Fluid Dynamics
					 Mass Transfer Mass Transfer
					 Plant Basics Plant Basics
					 Refining Refining
					 Safety Safety
					 Thermodynamics Thermodynamics
 Forums
   Forums Blogs
   Blogs Articles
   Articles File Library
   File Library Search
   Search FB
