| Category: | Bulk Solids |
| Question: | What is a "saltation velocity" and how is it used in designing pneumatic conveying systems? |
| Keywords: | pneumatic,conveying,saltation,velocity,design,gas |
| Answer: | The saltation velocity is defined as the actual gas velocity (in a horizontal pipe run) at which the particles of a homogeneous solid flow will start to fall out of the gas stream. In designing, the saltation velocity is used as a basis for choosing the design gas velocity in a pneumatic conveying system. Usually, the saltation gas velocity is multiplied by a factor, which is dependent on the nature of the solids, to arrive at a design gas velocity. For example, the saltation velocity factor for fine particles may be on the order of 2.5 while the factor could be as high as 5 for course particles such as soy beans. |
