 PIPESIZE PIPESIZE
| Category: | Chemistry Basics |
| Question: | How can arsenic be removed from aqueous waste streams? |
| Keywords: | arsenic,removal,ferric,chloride,waste,precipitation,floc,agglomerate |
| Answer: | Often times, ferric chloride is added to such a stream. The ferric chloride aids in the formation of floc to agglomerate fine arsenic particles that can then be removed by mechanical means. |
					 Bulk Solids Bulk Solids
					 Corrosion Corrosion
					 Fluid Dynamics Fluid Dynamics
					 Mass Transfer Mass Transfer
					 Plant Basics Plant Basics
					 Refining Refining
					 Safety Safety
					 Thermodynamics Thermodynamics
 Forums
   Forums Blogs
   Blogs Articles
   Articles File Library
   File Library Search
   Search FB
