Category: | Chemistry Basics |
Question: | What is the easiest way to extract hydrogen from water and the safest way to store it? |
Keywords: | hydrogen,water,storing |
Answer: | Electrolysis (which means splitting using electricity) of water is the method for producing hydrogen from water.The safest way to commercially store it would be to use a palladium "sponge", because palladium adsorbs several hundred times it's own volume in hydrogen. One would need to produce a compound with a very high surface area which has a thin coating of palladium. This type of material is commonly used as a catalyst in chemical processes. |
