| Category: | Chemistry Basics |
| Question: | What is the Wet Bulb Globe Temperature (WBGT)? |
| Keywords: | wet,bulb,globe,temperature,wbgt,definition, |
| Answer: | The sultriness of the ambient environment is more than a comfort factor. For workers, soldiers and athletes, high levels of sultriness may result in heat stress that could very well be life threatening. To determine the actual degree of sultriness in a quantifiable manner, the Wet Bulb Globe Temperature (WBGT) index is used. It includes the effects of humidity, air speed, air temperature and the radiant heating factor (from the sun). This index was developed by the U.S. Military in the 1950's and has become widely accepted for industrial temperature measurements to protect employees. It combines three temperature readings: the wet bulb temperature; the ordinary dry bulb temperature; and a black bulb globe temperature. There are also instruments available which measure WBGT index directly, combining the three factors and their appropriate weighting values. |
