Refinery Tankageankur2061 - May 10 2012 08:07 AM
Minimum Safe Flow for a Centrifugal Pumpankur2061 - Apr 27 2012 06:56 AM
Natural Gas Boiler CalculationsSadananda Konchady - Mar 29 2012 06:55 PM
Hydrate Formation Temperatureankur2061 - Feb 29 2012 09:26 AM
Compressor Surge and Anti-Surge Controlankur2061 - Feb 21 2012 05:01 PM
Crane Fluid Flow Examples in MS Excel 1.11Art Montemayor - Jan 31 2012 08:22 PM
Surface Tension of Pure Liquidsankur2061 - Jan 24 2012 02:43 PM
Filament Yarn Quench Air Systemankur2061 - Jan 18 2012 05:03 PM
Gravity Tank Drainage Calculator for Uniform Cross Sectionsstudent88 - Dec 19 2011 03:16 PM
Gravity Tank Drainage Calculator for Hemispherical Cross Sectionsstudent88 - Dec 19 2011 03:14 PM
Recent Status Updates
ChristaSChexpress is back with your latest news headlines - http://www.cheresources.com/invision/blog/17/entry-244-chexpress-may-22-2012/
Chris HaslegoNew Blog Entry - Human Factors Engineering in the Chemical Process Industry - http://www.cheresources.com/invision/blog/4/entry-243-human-factors-engineering-in-the-chemical-process-industry/
imranahmedkhanrespected seniors,i am a chemical engineer fresher looking for a job,my aim is to become an process engineer,but recently i have got an offer from a paint company in saudi arabia for the post of production engineer trainee,i have no idea about career growth in paint industry,with two years contract.,i request all of you to please help me understand whether i should accept this offer or not?can i switch to other industries like(petrochemicals,oil and gas) after 2 years??what are the career gro...
Show comments (1)
muhammadjunzhi iam 4th year Chemica Engineering Student. its now short time to final term , iam confused for final year project. can any one suggest me what to select/chose for project. please
Show comments (1)
| Question: | I would like to know how to size a partial combustion reactor processing methane and oxygen, as a function of the flowrate and of the pressure. |
| Keywords: | partial,combustion,reactor,methane,oxygen |
| Answer: | In your case, you essentially have two reactions:CH4 + 3/2 O2 ---> CO + 2 H2O (incomplete combustion)CH4 + 2 O2 ---> CO2 + 2 H2O (complete combustion)each of these reactions has a specific rate at which it occurs. If you wanted to design a reactor properly, you'd need to determine the conversion of methane in each of the above reactions. The upper limit of your flowrate is bound by the rate of reaction. If the flowrate is too high, the reaction simply won't take place (ie. the flame will burn out). I'm not sure that there is a simple relationship between pressure and flowrate in this case. The gases need to spend a certain amount of time in the reactor in order for the combustion to take place (residence time). Once you know the residence time, you could design a reactor for your specific flowrate. I expect that the residence time for a combustion reaction of this sort would be very small, although I cannot find an estimate anywhere. I recommend contacting the following people who should certainly be of more assistance:1. Combustion and Fuels Research LaboratoryDepartment of Mechanical EngineeringTexas A&M UniversityCollege Station, TX 77843-3123(409) 845-47052. Naval Research LaboratoryDr. Ronald S. SheinsonWashington, DC 20375(202) 404-8101**Uses 28 m3, 56 m3, and 840 m3 fire test compartments3. Dr. David T. Pratt**Specializes in computational modeling of combustion processesContact him with the link below |
| Links: | Contact Dr. David Pratt |
Array
