| Question: | How can I estimate a gas flow based on two pressure measurements? |
| Keywords: | gas,flow,estimation,pressure,drop |
| Answer: | You can use the Weymouth equation to estimate the gas flow. Below is the equation. The compressibility should be evaluated at Pavg shown below. Nomenclature is as follows:Q = flow rate, Million Cubic Feet per Day (MCFD)Tb = base Temperature, degrees RankinPb = base pressure, psiaG = gas specific gravity (reference air=1)L = line length, milesT = gas temperature, degrees RankinZ = gas compressibility factorD = pipe inside diameter, in.E = Efficiency factor E=1 for new pipes with no bends E=0.95 for pipe less than a year old E=0.92 for average operating conditions E=0.85 for unfavorable operating conditions |
| Images: |
