| Question: | How can I estimate the efficiency of a pump? |
| Keywords: | estimate,pump,efficiency |
| Answer: | The following method, developed by M.W. Kellogg, gives results within 3.5% of most manufacturers curves.Eff % = 80-0.2855H+3.78x10-4HF-2.23x10-7HF2+5.39x10-4H2-6.39x10-7H2F+4.0x10-10H2F2H = Developed head, ftF = Flow in GPM (gallons per minute)Applicable for heads from 50 to 300 ft and flows from 100 to 1000 GPM |
1 Comments
Dear Haslego, thanks for your sharing,
I have more question about estimating pump efficiency, how about:
a. when flow is below 100 GPM?
b. Head below 50 ft?
I have read Branan, but still not clear on the equation below 100 GPM.
Is it 35% x (100 GPM efficiecy) / GPM x (100 - GPM) ?
