Category: | Fluid Dynamics |
Question: | How can I determine the largest impeller that a pump can handle? |
Keywords: | maximum,impeller,size |
Answer: | The motor amperage should be measured in the field with the pump discharge valve wide open. Subtract about 10% from the pumps maximum rated amperage. Then the maximum impeller size can be determined from:A2 = A1(d2/d1)3A2 = Maximum amperage minus 10%A1 = Current operating amperaged2 = Maximum impeller diameterd1 = Current impeller diameter |
