 PIPESIZE PIPESIZE
| Question: | What is the significance of the minimum flow required by a pump? |
| Keywords: | shutoff,pump |
| Answer: | The minimum flow that a pump requires descibes the flow below which the pump will experience what is called "shutoff". At shutoff, most of the pump's horsepower or work is converted to heat that can vaporize the fluid and cause cavitation that will severely damage the pump. The minimum flow of a pump is particularily important in the design of boiler feed pumps where the fluid is near it's boiling point. |
					 Bulk Solids Bulk Solids
					 Corrosion Corrosion
					 Fluid Dynamics Fluid Dynamics
					 Mass Transfer Mass Transfer
					 Plant Basics Plant Basics
					 Refining Refining
					 Safety Safety
					 Thermodynamics Thermodynamics
 Forums
   Forums Blogs
   Blogs Articles
   Articles File Library
   File Library Search
   Search FB
