Refinery Tankageankur2061 - May 10 2012 08:07 AM
Minimum Safe Flow for a Centrifugal Pumpankur2061 - Apr 27 2012 06:56 AM
Natural Gas Boiler CalculationsSadananda Konchady - Mar 29 2012 06:55 PM
Hydrate Formation Temperatureankur2061 - Feb 29 2012 09:26 AM
Compressor Surge and Anti-Surge Controlankur2061 - Feb 21 2012 05:01 PM
Crane Fluid Flow Examples in MS Excel 1.11Art Montemayor - Jan 31 2012 08:22 PM
Surface Tension of Pure Liquidsankur2061 - Jan 24 2012 02:43 PM
Filament Yarn Quench Air Systemankur2061 - Jan 18 2012 05:03 PM
Gravity Tank Drainage Calculator for Uniform Cross Sectionsstudent88 - Dec 19 2011 03:16 PM
Gravity Tank Drainage Calculator for Hemispherical Cross Sectionsstudent88 - Dec 19 2011 03:14 PM
Recent Status Updates
ChristaSChexpress is back with your latest news headlines - http://www.cheresources.com/invision/blog/17/entry-244-chexpress-may-22-2012/
Chris HaslegoNew Blog Entry - Human Factors Engineering in the Chemical Process Industry - http://www.cheresources.com/invision/blog/4/entry-243-human-factors-engineering-in-the-chemical-process-industry/
imranahmedkhanrespected seniors,i am a chemical engineer fresher looking for a job,my aim is to become an process engineer,but recently i have got an offer from a paint company in saudi arabia for the post of production engineer trainee,i have no idea about career growth in paint industry,with two years contract.,i request all of you to please help me understand whether i should accept this offer or not?can i switch to other industries like(petrochemicals,oil and gas) after 2 years??what are the career gro...
Show comments (1)
muhammadjunzhi iam 4th year Chemica Engineering Student. its now short time to final term , iam confused for final year project. can any one suggest me what to select/chose for project. please
Show comments (1)
| Question: | How can I prevent this heat exchanger from fouling during turn down? Do you know of a good information source for phosphate solubility versus temperature and fluid velocity? |
| Keywords: | fouling,phosphate,heat,exchanger,shell,tube |
| Answer: | BACKGROUNDA shell-tube heat exchanger (double pass) has cooling water @ about 110-115 0F and weak nitric acid containing some organics @ about 155-160 0F. We treat our cooling water to prevent both phosphate and carbonate scaling. When we pulled this heat exchanger out of service, we observed severe fouling on the outlet side of the cooling water, but very minimal fouling on the inlet of the cooling water. Although our cooling water chemical treatment could use some improvement, I suspect that most of the fouling is due to the fact that when we operate our plant at reduced production rates, we also operate this exchanger with minimal weak nitric velocities. In order not to under cool the weak nitric, thereby causing any organics in the fluid to solidify, we throttle back our cooling water velocities. Now, because the cooling water is moving at 50-75% less than normal operating velocities, and still heating up, we believe lowers the solubility of phosphates in the cooling water, thereby depositing phosphate scaling at the outlet side of our exchanger.RESPONSEI agree completely with your assessment of the situation (this happens often). I see a description of a calculation method for solubility in a book entitled "Properties of Liquids and Gases" by Robert C. Reid (McGraw-Hill...this is a fairly common book). The calculation procedure requires quite a bit of knowledge of the solid substance and frankly, I'd feel better with experimental or practical data (as is mostly the case), but I don't recall seeing anything like that in the past. I'm assuming that you've already eliminated the possibility of removing the set point for the water flow and allow the flowrate of the water to remain the same during scale-down. This would certainly keep the water at a temperature low enough to prevent the deposits. Is this not an option? Or you could always trial and error the water flow down to a rate where the deposits are minimized and then I'd recommend recording that water outlet temperature for future use. |
Array
