 PIPESIZE PIPESIZE
| Question: | What is a good, general correlation for the friction factor on the shell side of a shell and tube heat exchanger? |
| Keywords: | shell,side,friction,factor |
| Answer: | For a shell-side Reynolds Number <500: f = 0.11183/Re0.59246 (error as much as 20%)For a shell-side Reynolds Number >500: f = 0.01159/Re0.18597 (more accurate) |
					 Bulk Solids Bulk Solids
					 Corrosion Corrosion
					 Fluid Dynamics Fluid Dynamics
					 Mass Transfer Mass Transfer
					 Plant Basics Plant Basics
					 Refining Refining
					 Safety Safety
					 Thermodynamics Thermodynamics
 Forums
   Forums Blogs
   Blogs Articles
   Articles File Library
   File Library Search
   Search FB
