Control Valve Sizing - Single and Two Phase
Ajay S. Satpute - May 11 2015 09:15 AM
Fire Case Load for Vessels - API 521 6th Edition
Ajay S. Satpute - Feb 03 2015 04:00 PM
Thermal Relief Load and Pressure Rise Calculator Rev 1
Ajay S. Satpute - Jan 14 2015 08:24 PM
Recent Status Updates
Ajay S. Satpute
Hi, I have started my own engineering consultancy in India. Converge Engineering Pvt. Ltd. For more information, please visit www.converge.net.in
Category: | Industrial Utilities |
Question: | What could be a possible cause for sudden foaming in a cooling tower? |
Keywords: | cooling,tower,foaming,leaking,heat,exchanger |
Answer: | Assuming that no other changes have been made, especially to the water treatment chemicals, the most common outcome to this mystery is a leaking heat exchanger. Begin a systematic check of all of the heat exchangers that use the cooling tower water and inspect them thoroughly for leaks. Even small amounts of some chemicals can cause big foaming problems in the tower. Also, not all of these components will set off a conductivity alarm. |
