| Category: | Mass Transfer |
| Question: | What is a good source of equations for calculating discharge flowrates from accidental releases? |
| Keywords: | accidental,discharge,flow,rate,calculations,equations |
| Answer: | If you are interested in the calculation of discharge flow rates from accidental releases, read the online technical article "Source Terms for Accidental Discharge Flow" at the website below.It provides the equations used for a variety of common types of accidental gas or liquid releases and explains how to use them. |
| Links: | Source Terms for Accidental Discharge Flow |
