Gas Volume Fraction versus Gas Oil Ratio for Upstream Well Datavskumar - Apr 29 2013 01:15 PM
Critical Velocity of Heavier Than Air Flammable Gasesankur2061 - Apr 29 2013 12:32 PM
Pipe Heat LossSteve Hall - Apr 29 2013 12:21 PM
Heat Capacity Ratio Compilationankur2061 - Apr 08 2013 10:56 AM
Thermophysical Property Correlations Provided By Dipprankur2061 - Mar 06 2013 10:02 AM
PNG 520 - Phase Equilibria in Crude Oil and GasArt Montemayor - Feb 21 2013 06:39 PM
Maximum Allowable Pressure of Pipes and Pipelinesvskumar - Feb 12 2013 12:05 PM
Glycol Dehydrator Design Manual - 1976Art Montemayor - Feb 12 2013 10:53 AM
Steam Ejector Calculation Notesankur2061 - Feb 12 2013 10:38 AM
Amine Acid and Sour Gas Plant ExperiencesArt Montemayor - Feb 12 2013 10:28 AM
Recent Status Updates
Chris HaslegoAnkur just published one of those blog entries that will be referenced around the internet for years to come. This is really great stuff! Perforated Pipe Distributor Sizing Calculations (otherwise know as "How to Size a Sparger") at http://www.cheresources.com/invision/blog/4/entry-353-perforated-pipe-distributor-sizing-calculations/
ChristaSCheck out the latest Chexpress headlines here: http://www.cheresources.com/invision/blog/17/entry-352-chexpress-may-14-2013/
| Category: | Physical Property Information |
| Question: | Where can I find physical properties for water-methanol solutions? |
| Keywords: | water,methanol,solution,densities,density,physical,properties |
| Answer: | Table 3-109 on page 3-88 of the Sixth Edition of "Perry's Chemical Engineers' Handbook" has the densities of aqueous methyl alcohol solutions ranging from 1 weight percent solution to 100 weight percent, and 0 0C to 20 0C temperature. |
