 PIPESIZE PIPESIZE
| Question: | Are there any special considerations to be taken into account for combusting ammonia? |
| Keywords: | ammonia,combustion |
| Answer: | The heat of combustion of ammonia is 8,000 Btu per pound as compared to about 18,000 Btu per pound for most liquid hydrocarbon fuels. There is no reason why it cannot be combusted with or without auxiliary fuel. However, ammonia combustion does result in a flue gas having a high concentration of NOx and the design of a combustion chamber for ammonia requires special conditions to mitigate or reduce the level of NOx emissions. |
					 Bulk Solids Bulk Solids
					 Corrosion Corrosion
					 Fluid Dynamics Fluid Dynamics
					 Mass Transfer Mass Transfer
					 Plant Basics Plant Basics
					 Refining Refining
					 Safety Safety
					 Thermodynamics Thermodynamics
 Forums
   Forums Blogs
   Blogs Articles
   Articles File Library
   File Library Search
   Search FB
