Category: | Plant Basics |
Question: | While there are many tests available to detect leaks on vessels, is there a technology available to quanitify the leak or measure the flow through a leak? |
Keywords: | leak,detection,measuring,quanitify |
Answer: | The RheoVac air in-leak monitor by Intek, Inc. in Westerville, OH is a viable meter that gives the actual air in-leakage flow rate. It also gives you exhauster capacity and a vacuum quality reading. If you want to find more information you can view their web site below. |
Links: | IntekFlow |
