Category: | Plant Basics |
Question: | What is a common cause of getting water, solvents, or other liquid into inert purge lines? |
Keywords: | v1i10,inert,line,condensible,solvent,water,liquid,condense,condensation,condensing,avoid,check,valve,nitrogen,argon |
Answer: | One of the most common causes of this situation is the lack of a check valve at the point of use. If an inerting system is being used to charge a vessel containing a liquid, and the system contains no check valve, the vapors can make their way into the inert line and condense later.Although this seems like an obvious feature of such a system, it's omission is not uncommon. |
