| Category: | Plant Economics |
| Question: | Is there a quick way to estimate annual pumping costs for a given pipe size and flow rate? |
| Keywords: | v1i14,pumping,pump,cost,annual,calculation,estimate,estimation |
| Answer: | If set up in a spreadsheet, the formula below could easily be used with metric units of measure as well. For quick estimates, use a friction factor of 0.02 (probably a little conservative for most cases). |
| Images: |
