 PIPESIZE PIPESIZE
| Question: | Is there a good way to recover platinum and rhenium from the spent aromatization catalyst of naphta processing? |
| Keywords: | spent,catalyst,ion,exchange,rhenium,platinum,anionic,resin |
| Answer: | This paper presents the recovery of the nobel metals , platinum and rhenium from the spent aromatization catalyst of naphta using anion exchange resins. the catalyst is solved in a mixture of sulphuric acid and aqua regia , and the produced solution is passed through the columns which contain the ion exchange resins . The platinum and rhenium that exist in the solution are adsorbed on the resin , then the resin is washed by the means of a suitable acid and platinum and rhenium are desorbed from resin. The different parameters which affect the process of desorbtion and adsorption are also considered and the best condition for the maximum efficiency is determined. The efficiency has been 100% in the adsorption process and over 95 % in the desorbtion process. |
| Links: | Download this detailed report |
					 Bulk Solids Bulk Solids
					 Corrosion Corrosion
					 Fluid Dynamics Fluid Dynamics
					 Mass Transfer Mass Transfer
					 Plant Basics Plant Basics
					 Refining Refining
					 Safety Safety
					 Thermodynamics Thermodynamics
 Forums
   Forums Blogs
   Blogs Articles
   Articles File Library
   File Library Search
   Search FB
