 PIPESIZE PIPESIZE
| Question: | Can you provide some information on the solubility of lithium nitrate? |
| Keywords: | solubility,lithium,nitrate |
| Answer: | LiNO3 is soluble is water, 95% ethanol (ethyl alcohol), and ammonia. It may also be soluble in some other organic solvents, but these one for certain.It most likely decomposes at about 500 0C by the following reaction:2LiNO3 (s) ---> 2LiNO2 (s) + O2 (g)Hydrates can be formed by the attachment of 3 water molecules, but I don't know the reaction conditions. It may just absorb water from the air, but maybe not. If you have some and it begins to "grow" a film when exposed to air, this is what is happening.LiNO3 + 3H2O ---> LiNO3.3H2O (the water molecules literary become attached to the lithium nitrate)If you need more information, check a public library for a book called the "Merch Index", or contact a company that manufactures the chemical. They should be able to answer your questions as well. |
					 Bulk Solids Bulk Solids
					 Corrosion Corrosion
					 Fluid Dynamics Fluid Dynamics
					 Mass Transfer Mass Transfer
					 Plant Basics Plant Basics
					 Refining Refining
					 Safety Safety
					 Thermodynamics Thermodynamics
 Forums
   Forums Blogs
   Blogs Articles
   Articles File Library
   File Library Search
   Search FB
