Determining Potential Natural Gas Liquids (Ngl) In A Natural Gas Stream
Determining Potential Natural Gas Liquids (Ngl) In A Natural Gas Stream Dear All,
The amount of potentially recoverable NGL based from a natural gas stream can be estimated from the following formula:
Potential NGL component (tons per annum) = V*y*CF
V = Volume flow rate of natural gas, MMSm3/day (Std conditions are P= 1.01325 bara, T = 288.15K)
Note: MM= Million
y = mole percent of the component in natural gas
CF = Component factor (see table below)
Example: 3 MMSCMD of NG is available for processing. This gas contains 5.4% mol propane. What is the potential propane recovery from the NG?
Calculations:
Potential Propane Recovery (w/o Recovery factor and plant on-stream factor) = 3*5.4*6800 = 110160 t/a
Considering a plant recovery factor of 70% and plant on-stream factor of 335 days, the average propane recovery per annum would be:
110160*0.7*(335/365) = 70,770 tons per annum (t/a)
That is all for today. Any comments are welcome.
The component factor looks like the density of the gas at standard conditions isn't it ?
I don't think so. Not at least in conventional density units such as kg/m3. What I have written is referenced from Shell manual.
The figures seem to be estimated from the (1) volume rate in 10^6 Sm3/d (2) number of days a year, 365 d/y (3) molecular volume 23,645 Sm3/ton-mole (4) molecular mass, (MW) t/t-mole (5) concentration, C m% (5) and each recovery factor, f -
Component Factor ≒ (10^6 Sm3/d)* (365 d/y)  / (23,645 Sm3/t-mole) * (MW t/t-mole) * ( C m%/100%) * (Recovery factor f, -) = 154.37*(MW)*©*(f)........(1)
C2:   4,642 f  = 4,600
C3:   6,940 f  = 6,800
C4:   8,972 f  = 9,000
C5:  11,137 f = 11,100
C6:  13,302 f =  13,300
The component factors "CF" have the similar values as the products of (standard state molar density MW/Sm3) multiplied by the factor (10^6 *365 Sm3/y/100%), and some recovery factor, f
~Stefano
Hi Stefano,
Explain CF with more clear examples and equation for CF calculations.
    Mithun_mk
    Yesterday, 07:10 PM
    Bitan729
    Yesterday, 02:01 PM
    kay50
    11 Mar 2026 - 22:29
    AnhStevie86
    11 Mar 2026 - 09:42
    HOTTEST
    11 Mar 2026 - 09:04
    deepakveer.21
    11 Mar 2026 - 05:39
    10 Mar 2026 - 19:21
    mikeophio
    10 Mar 2026 - 15:10
    Sudhirenju
    09 Mar 2026 - 10:39
