Firewater System Design
#1 asade abiodun
asade abiodun
  • 146 posts
Posted 29 March 2010 - 06:04 AM
Goodday all,
I need to design a firewater system for a booster compressor station, but i dont know how to go about it. Please, i would appreciate if somene can give me guidelines on how to determine the quantity of firewater needed and determine the quantity of foams to be used.
Thanks for the anticipated coperation.
Happy Easter in advance... :rolleyes:
#2 ankur2061
ankur2061
  • Forum Moderator
  • 2,484 posts
Posted 29 March 2010 - 09:58 AM
Goodday all,
Asade,
Try to read through NFPA 15. It gives clear guidelines how to calculate 'demand' and also other design guidelines for system design.
For fire fighting foams refer NFPA 11.
If you are finding it difficult to arrive at a preliminary design such as fire water & foam demand from the above mentioned references then you are advised to hire the services of a specialist consultant in fire fighting services to prepare a basic design package for your plant/unit. These specialists do such kind of work day in and day out & should be able to meet your requirements.
Edited by ankur2061, 29 March 2010 - 09:59 AM.
#3 asade abiodun
asade abiodun
  • 146 posts
Posted 29 March 2010 - 10:47 AM
Thanks Ankur
I will go through it.
#4 Qalander (Chem)
Qalander (Chem)
  • 829 posts
Posted 29 March 2010 - 11:48 AM
Thanks Ankur
Dear
I am ready to assist/guide in any way if you face difficulty anywhere with my humble support.
Basic starting points one should be clear about is the hazard itself i.e.
Coprocessor Type (Reciprocating,Centrifugal or Turbine),service and
extent of pressurization and
Quantity of Flammables& or Combustibles forming worst credible scenario etc, etc.
Accordingly Gas Compressors may require a Combination of automatic CO2(or Inergen) and Water Mist(Fog) shielding system for cooling and smothering.
I googled and a lnik for you
http://ieeexplore.ie...thDecision=-203
Another Great Article By "Ram K. Saini, PE, and Charles Emma, PE, Burns and Roe Enterprises Inc." in Power magazine March 2007
You may google or send your email to avoid Copyright infringement issues as I prefer restricted use only.
Edited by Qalander (Chem), 29 March 2010 - 12:41 PM.
#5 Qalander (Chem)
Qalander (Chem)
  • 829 posts
Posted 29 March 2010 - 01:25 PM
Thanks Ankur
Dear
Dear Luckily I found this as pdf& attach
Hope this helps!
#6 asade abiodun
asade abiodun
  • 146 posts
Posted 30 March 2010 - 12:51 AM
Thanks Qalander for your assistance.
my email is ashjanj18@yahoo.com.
Appreciate your assistance.
#7 Qalander (Chem)
Qalander (Chem)
  • 829 posts
Posted 30 March 2010 - 11:15 AM
I think Some basic data& details missing on your part or if you have made some progress discuss that out, I will glad to send help/assist once the case takes shape.
I send you a test email or you if do not want to share details may use PM's or email means
