Where can I find tables with numerical values of compressibility factor (Z) for carbon dioxide (CO2) as a function of gas temperature and pressure. (books, articles...)
Thank you in advance!
Alison
Compressibility Factors For Carbon Dioxide
Started by Alison, Apr 11 2010 12:14 PM
Posted 11 April 2010 - 12:14 PM
Posted 11 April 2010 - 12:48 PM
Alison,
There is a table (Table 2-167) in Chapter 2, Physical & Chemical Data of "Perry's Chemical Engineering Handbook", 7th edition (this is the one I have) which provides the compressibilities of CO2 with respect to various temperatures & pressures.
Posted 11 April 2010 - 01:23 PM
Here's the table mentioned by Ankur.
You can try to use the following website and see if the calculator gives reasonable accuracy/match with the values from Perry: http://www.carbon-di...s.com/help.aspx
Posted 13 April 2010 - 10:12 AM
You could try this: http://www.lv-soft.c...stoff/index.htm for CO2 properties or NIST database.
Posted 15 April 2011 - 06:45 AM
Somebody know equation?
Edited by Misterry, 15 April 2011 - 06:49 AM.
Posted 16 April 2011 - 01:48 AM
let you try the search button ( top right) and you get your answer
![]() Activated Carbon SelectionStarted by Guest_Talhafarooq_* , 25 Nov 2024 |
![]() ![]() Carbon Bed Filter CalculationsStarted by Guest_kyayura_* , 25 Jul 2023 |
![]() Carbon Capture Absorber SimulationStarted by Guest_raisoturu_* , 21 May 2024 |
What Are The Differences Between Ph,orp & Chlorine Dioxide AnalyseStarted by Guest_Radha Krishnan Siva Kumar_* , 01 Apr 2024 |
Design Margins Instead Of Fouling FactorsStarted by Guest_Vegeta_* , 12 Dec 2023 |
