can someone help me find problems on solving the height of Gas Absorption Packed Towers using NG or NL including the reference book. thank u.
Gas Absorption Packed Bed Towers
Started by Guest_divine_*, Feb 16 2005 12:56 AM
Guest_divine_*
Posted 16 February 2005 - 12:56 AM
Guest_naeem_*
Posted 11 September 2005 - 01:24 PM
QUOTE (divine @ Feb 16 2005, 12:56 AM)
consult the books like
coulson and richardson"chemical engineering"volume 2 and 6
Posted 19 September 2005 - 01:36 AM
Reinhard Billet PACKED TOWERS in processing and environmental engineering
VCH Verlagsgesellshaft
ISBN 3-527-28616-0 (1995)
THer are detailed examples at the end of the book, exactly what you want
Guest_Guest_*
Posted 02 October 2005 - 05:52 AM
QUOTE (divine @ Feb 16 2005, 12:56 AM) <{POST_SNAPBACK}>
Try Process Plant design by Ludwi.Excellent text!
Guest_Guest_John_*_*
Posted 28 October 2005 - 08:19 AM
But how to decide the flue gas velocity, the diameter and height of tower and the pressure drop?
thanks
thanks
Posted 15 November 2006 - 01:26 PM
QUOTE (Guest_John_* @ Oct 28 2005, 02:19 PM) <{POST_SNAPBACK}>
thanks
thanks
I think pressure drop for absorption in packed bed requires 16 - 48 mmH2O/m packing. Then you choose a kind of packing with packing ratio. Flue gas velocity is mostly set in a company. Diameter is found through the Sherwood correlation requiring G and L flow also the kind of packing. If the packing ratio doesn't concur with your diameter, then you choose a smaller packing.
For the Height of the tower you look at the packing of a company and gather information about G/L ratio, kind of packing, absorption system and HTU. Then you can calculate your L flow from your gas flow. It's this L flow you need for the Sherwood Correlation. Then you calculate NTU: you need the slope of the equilibrium line of your system. With the Colburn equation you calculate NTU. (Or you could estimate everything with Henry...)
Height of tower = NTUxHTU
I'm just a student so...
If it isn't correct please notify me of my mistake, because I'm designing it this way and I hope it's the right method.
![]() Multi-Tubular Packed Bed ReactorStarted by Guest_shambola_* , 12 Feb 2025 |
![]() How Can I Simulate An Adsorption And Deoxidization Towers In Aspen HysStarted by Guest_Ahmed.Loutfi_* , 03 Nov 2024 |
Electric Heater In Regeneration Absorption BatteryStarted by Guest_alaasleem2026_* , 01 Sep 2024 |
Choice Of Model To Packed Bed ReactorStarted by Guest_Kakashi-01_* , 06 Dec 2023 |
