Hello everyone,
I am still working on the analysis of lubricating oil and have been asked to analyse a particular grade of different brands of lubricating oil(like chevron,mobil,etc) and to suggest the best of these brands. My problem is that I don't know what properties to test for in these oils.I have been thinking of pour point,flash point and so on but don't really know how this can distinguish these oils.I would appreciate any suggestion.Thanx.
Lubricating Oil Analysis
Started by ukpeters, Jun 19 2003 12:23 PM
Posted 19 June 2003 - 12:23 PM
Guest_Dave_*
Posted 23 June 2003 - 02:20 PM
have you tried actually approaching lubricating oil manufacturers? Their information will probably be better than anyone elses, and lots of companies will help students with projects if they're asked.
The lubricating oil manufacturers should be able to provide MSDS data for their products-I'm pretty sure it's a legal requirement in the UK to be able to provide this data, at least with an order. I certainly received MSDS data when I was buying in some lubricating oil when I was on an industrial placement.
The data they provide should contain all the usual flashpoints, LEL/UOL etc, maybe there will be enough difference between different grades for you to tell the difference if you do some analysis.
You may even be able to get MSDS data on the web - I entered 'lubricating oils MSDS' as a google search and got some MSDS sheets for Chevron etc.
A table showing equivalent lubricating oils may be found at http://www.mts-nw.com/oil%20chart.htm.
I suggest you also think about what makes an oil the 'best' oil - are we talking value for money, longevity, purity etc.
Dave
Dave
Surge Analysis-Control LogicsStarted by Guest_stu_* , 30 Dec 2024 |
![]() ![]() Two Phase Analysis For Liquid Oxgen TankStarted by Guest_alaasleem2026_* , 22 Aug 2024 |
Analysis Of Ammonia Content In EthyleneStarted by Guest_Movers_* , 04 Jun 2024 |
![]() Aspen Plus - Sensitivity Analysis / Case Study - Need AssistanceStarted by Guest_SickPuppy0_* , 07 Feb 2023 |
![]() Exergy And Sustainability Analysis Of Batch Distillation Of OilStarted by Guest_waheed2020_* , 24 Jan 2022 |
