Hi guys
m lookin for a book which deals in calculation for furnace in refinery. Can any 1 help me in this regard..?
Thnx in advance
Refinery Heater/ Furnace Calculation
Started by Ahsan Jalal, Apr 21 2010 12:01 PM
Posted 21 April 2010 - 12:01 PM
Posted 21 April 2010 - 01:22 PM
Ahsan,
Twos sources you can refer to:
1. API STD 560 Fired Heaters for General Refinery Service- Annex G, Measurement of efficiency of fired-process heaters. Sub-section G.3 deals with Determination of thermal & fuel efficiencies
2. Handbook of Petroleum Processing, David Jones & Peter Pujado, Section 18.5 - Fired Heaters
Hope this helps.
Hope this helps.
Posted 22 April 2010 - 12:58 AM
I have done one myself. There is a lot of literature on the web. Hydrocarbon processing has some really good articles. I can give you the issues if you have access to them.
I assume you are going for the indirect method.
A good article came out on the July 2003 issue
"Flue gas analysis - a storehouse of information
Here's a step-by-step procedure to determine heater performance
R. K. GHOSH, Haldia Refinery, Indian Oil Corp., West Bengal, India"
This can be a good starting point.
If you need any more info, feel free to ask. I would also suggest to use this as a starting point and do your own calcs to be clear on things.
Posted 04 May 2010 - 09:27 AM
Do these literatures also contain the method to calculate the draft (pressure) inside the furnace? I need one...
Thank you very much...
Posted 04 May 2010 - 11:06 AM
Skyline,
The "Handbbok of Petroleum Processing" gives an equation for heater draft which is as follows:
D = 0.187*H*(rhoa-rhog)
where:
D = draft in inches of water
H = height of stack in feet
rhoa = densiy of atmospheric air in lb/ft3
rhob = density of stack gases in lb/ft3at stack conditions
Notes:
1. Stack gas temperatures are lower by approximately 100 deg F than gases leaving the convection section.
2. Stack gases have a molecular weight close to that of Nitrogen.
3. Burner draft requirements are in the range of 0.2 to 0.5 inches of water.
Hope this helps.
Selection Type Of Heater For Refrigerated PropaneStarted by Guest_livetolove003_* , 07 May 2025 |
Hcl Fumes CalculationStarted by Guest_Chemeng40_* , 16 Oct 2024 |
Hydraulic CalculationStarted by Guest_applepe_* , 06 Oct 2024 |
