Dear all,
I am currently sizing a two phase horizontal separator fitted with vane type demister for a Shell project. My reference is DEP 31.22.05.11" Gas/liquid separators - Type selection and design rule. Horizontal separator is selected due to head room restriction. To prevent liquid carryover to pipeline and the slightly waxy nature of the fluid, I've selected vane type demister. According to DEP, vane type demister is not suitable when the operating pressure is higher than 100 bar.
As my separator operating pressure is 100-110 bar, therefore would appreciate if someone can advise why vane type demister is not recommended for pressure >100bar. Is it purely because efficiency of the vane pack demister is significantly decreased or because of some other mechanical issue?
Please advise.
Hooi
Limitation Of Vane Pack Demister
Started by mkhooi, Apr 29 2010 07:35 PM
No replies to this topic
Posted 29 April 2010 - 07:35 PM
Demister Pad CalculationStarted by Guest_Avalon_* , 04 Nov 2020 |
Limitation For The Velocity At The Outlet Of The PsvStarted by Guest_bp77_* , 16 Oct 2020 |
Velocity Limitation In Tube Side Of Air Cooled Heat ExchangerStarted by Guest_ChemiFreak_* , 08 Aug 2017 |
Pvsv Back Pressure LimitationStarted by Guest_chem2013_* , 28 Jan 2017 |
Damage On Separator Vane Pack Due High Gas VelocityStarted by Guest_ElĂ_* , 03 Nov 2016 |
