I'm working on a solvent recovery system. i felt that there is too much loss during distillation.
I suppose the area of condenser being used is insufficient to handle the amount of vapors entering it.
I don't have any provision to check the vapor flow rate into the condenser.
and that's basically what i need.
so can anybody lemme know how to calculate the rate of vapor generation in the batch reactor?
And i tried the logic that the heat vapors are losing...is being gained by the utility in the tubes i.e. cooling water.
so the equation is:
mCdT of utility = m*Lambda + mCdT of liquid
but this equation yields a very high vapor in rate while the liquid out rate is just 500 L/hr.
can somebody tell me where i'm making a mistake or any better idea to check the area?
Thanks & Regards
Check For Condenser Area
Started by Guest_coolnick_*, May 27 2010 05:40 AM
No replies to this topic
Guest_coolnick_*
Posted 27 May 2010 - 05:40 AM
Vacuum Total Condenser With Flooded Surface Control During TurndownStarted by Guest_unvecchietto_* , 02 Jul 2026 |
Surface Condenser (Htri)Started by Guest_Prim_* , 08 Apr 2026 |
Surface Area Calculation For Blowdown Orifice Sizing Including FinnedStarted by Guest_victortheone_* , 17 Feb 2026 |
Condenser DesignStarted by Guest_Kentucky08_* , 07 Dec 2025 |
